This should be very silly but I cannot figure out properly how to mount the mirror arm. I have the one sold by Midwest.
I've used the search engine here, and either there are no pictures on threads talking about it ( ), they have been deleted or are very blurry/small. Christ, I've even searched in Steel Soldiers and same thing. I'm going insane.
The mount from Midwest seems to be straight forward but I want to prevent any problem when the can support is arriving.
Can people post pictures and give a measure with regards to the door's side?
Thanks.
Passenger side mirror, mounting pics needed.
- mount_passenger.jpeg (89.71 KiB) Viewed 2973 times
Sebastian
Re: Passenger side mirror, mounting pics needed.
Your cab is missing the two 7/16" fine nuts in the location of your bracket.
Maybe lost in the bodywork restoration?
Feel around inside the body and see it they are there, just filled in with Bondo.
Here you go !
What?? There are two holes there?
I need to check this out.
Thanks, I will take a look and update here.
Sebastian
There are supposed to be 2 threaded inserts in the body. Not only for the mirror, but also to hold the deep water fording intake pipe.
No thread inserts. We spent a couple of minutes there looking, checking, analyzing LOL!, trying to "feel" the steel and nothing. And this side of the truck was not replaced.
Anyways, per Andy's photo we measured and will align next for drilling.
- IMG_0276.JPG (74.27 KiB) Viewed 2871 times
Sebastian
I wonder if they were deleted in later trucks for cost reduction. A bunch of goodies disappeared on later trucks to cut cost. What year is the truck?
1952, I don't think too much changes are there.
Sebastian
