ez8 wrote:I'm looking forward to seeing more pictures and progress on this project - looks like great fun!
Thank you EZ8. Here is one new picture.
After a serious back injury on 8/21 while helping a cousin prepare for hurricane Laura and after many, many sessions of physical therapy, I am feeling better and strong enough to continue the project. I just removed the transfer case. Today or tomorrow I will be removing the engine so I can finish the chassis. One day at a time...
Tony
USAF SP/SF Vet
1963 Dodge M37B1
1955 Dodge Power Wagon
BTW, I meant to ask the community this question, but I hit the submit button too fast.
I went to PepBoys and rented a jaw puller. My intention was to use the puller to remove the steering wheel. According to the TM, there is a specific tool for that, but PepBoys, Advanced, AutoZone or the local auto parts didn't have it.
I've been spraying PB Blaster for a month or so hoping that it will do PB Blaster's magic in conjunction with the jaw puller. I tried and tried but I wasn't successful. I guess I will need to find the proper tool. Two questions:
1-Any of you know where to buy it?
2-If you have one, any of you willing to loan it or rent it for a couple of days? I will return it promptly via USPS Priority Mail Service, with tracking number and insurance. Of course, I will pay shipping both ways.
Thanks!
Tony
USAF SP/SF Vet
1963 Dodge M37B1
Glad your feeling better, pace yourself. There used to be a yoke/three jawed puller floating around, when I needed it went missing, I ended up restoring my steering wheel in place. It turned out real nice, I think there's a Youtube video's of several wheel restorations?
m-37Bruce wrote:Glad your feeling better, pace yourself. There used to be a yoke/three jawed puller floating around, when I needed it went missing, I ended up restoring my steering wheel in place. It turned out real nice, I think there's a Youtube video's of several wheel restorations?
Thanks Bruce.
Tony
USAF SP/SF Vet
1963 Dodge M37B1
If all else fails, PM me about borrowing my puller.
Thanks for the link and thank you for the offer Gary.
That idea is brilliant. I will give it a try and let you know. My only concern is that the steering wheel is in very bad shape and fragile. Hopefully I won’t destroy it using that method. My plan is to restore it.
Tony
USAF SP/SF Vet
1963 Dodge M37B1
Whatever method you use, don't apply downward pressure solely to the shaft itself. Put the nut on "flush" with the top end of the shaft-that way you won't bugger up or collapse the shaft end. I use the flat side of a big socket on top of the nut and shaft so you're pushing evenly across the entire shaft/nut surface, and you'll still have a little room for the wheel to move up when it gives way.
Cal_Gary wrote:Whatever method you use, don't apply downward pressure solely to the shaft itself. Put the nut on "flush" with the top end of the shaft-that way you won't bugger up or collapse the shaft end. I use the flat side of a big socket on top of the nut and shaft so you're pushing evenly across the entire shaft/nut surface, and you'll still have a little room for the wheel to move up when it gives way.
Ok. I’ll keep that in mind.
Tony
USAF SP/SF Vet
1963 Dodge M37B1
four pulley means it has the 100 amp alternator. Not the 25 amp generator. I have that and run other things like a big extra full flow oil filter system, handles the power needed fine. Keep us posted. HC
NAM VET wrote:four pulley means it has the 100 amp alternator. Not the 25 amp generator. I have that and run other things like a big extra full flow oil filter system, handles the power needed fine. Keep us posted. HC
That's good to know. I didn't know about those alternators until yesterday. Unfortunately this is the parts truck and most of the accessories were missing. I bought it mainly for the chassis and it also included the engine, transfer case, transmission, both diffs and some usable body parts.
Tony
USAF SP/SF Vet
1963 Dodge M37B1
That tailgate on your parts truck is worth more than the truck- very hard to find in that good a shape. Most that you find for sale look like flattened pretzels! Welcome.
06boblee wrote:That tailgate on your parts truck is worth more than the truck- very hard to find in that good a shape. Most that you find for sale look like flattened pretzels! Welcome.
It looks better in pictures. I am hoping to make a decent one out of the two.
Tony
USAF SP/SF Vet
1963 Dodge M37B1
