PTO drive shaft pictures
UTTAS
Post by UTTAS »
Hey friends,
Looking for some pics of the fwd and aft ends of the PTO drive shaft for the M-37. I reciently aquired a second winch and both have had the fwd end attached the the lu-4. Both came off an M-715 and both are different. I'm looking to see the correct set up for an M-37. I have located a shaft but still need a PTO to be complete. Any help is much appreciated to get her original prior to paint for an original WW.
Uttas
1942 Willys MB Slat Grill 114640
1952 Strick M-100 Trailer
1958 Dodge M37B1 L245-1196
Re: PTO drive shaft pictures
I'll be back home in a week or so, and will shoot some pics of my PTO parts and get them to you. HC
UTTAS
Post by UTTAS »
I'm still looking for picture help.
I should be able to post some Friday afternoon, UTTAS, as my PTO shaft is out of the truck right now.
Sorry-a little late but these should help. The top photo has the winch end of the shaft in view. I reversed it in the other two.
As you can see, I need to replace the U-Joint in the PTO end of the shaft; you also see an NOS end shaft still in Cosmoline next to it, and a replacement NOS U-joint in red primer as well.
m37 pto shaft 3.jpg (461.14 KiB) Viewed 1386 times
m37pto shaft2.jpg (615.07 KiB) Viewed 1386 times
m37 pto shaft1.jpg (138.62 KiB) Viewed 1386 times
UTTAS
Post by UTTAS »
Cal_Gary, thank you so much for the pictures!! It appears I do have both ends. I'll do some investigating today.
UTTAS
Anytime, Friend!
