installing some lockers. the bearings in the diffs are new..... is it possible to pull the bearings off the carrier without cutting up the carrier? I cant see a way without damaging the cage.
.... anyone have timken part numbers for the carrier bearings and cups ?
method or part # carrier bearings
Re: method or part # carrier bearings
Split bearing puller will remove the bearings.
Bower number will cross to Timken, might even be same number,
Can't remember.
33891 Cup
33821 Cone
Tom
Can't remember.
33891 Cup
33821 Cone
Tom
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
i guess my split puller has too much china on it to work.
thanks for the numbers.
