I was rebuilding a used M37 master cylinder I picked up at a meet for cheap and broke off the brass vent valve that attaches to the lid. So I started looking around locally for the same valve, but as with most parts this old you know the drill.......it couldn't be found. The NAPA guy gave me that look again.
So I went to the ORD 9 and found the original manufacturer's name, which was Weatherhead, and started looking online. Much to my surprise Weatherhead is still in business (but now owned by Eaton) and making brass valves and fittings. The ORD part number was useless, but I was able to actually find the valve in question after an hour or so of catalog diving, as well as the little 90 degree elbow that attaches the valve to the flared vent line tube. Digging deeper into some diesel engine forums I found that NAPA actually carries this valve (part number WH 6820) but they want like $14 for one. More digging online and I found a company called MSC Industrial that has them for less than $5. So I ordered a handful along with a bunch of 90 degree elbows (ORD says I need 5 for my truck) and even the shipping wasn't bad. A few other industrial supply houses had these parts but just kill you on shipping.
So if anyone ever needs to replace that vent valve on the master cylinder or the 90 degree elbow, the Weatherhead part numbers are;
Needle Valve 1/8 Male Pipe to 1/8 Female Pipe): PN 6820
Elbow (3/16 Tube to 1/8 Male Pipe): PN 402X3
Probably more useless info for most, but just in case there's one frustrated M37 owner out there kicking the dog because he can't find a master cylinder vent valve..........this info is for you. Now leave that damn dog alone you sicko.
