http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0238575420
Check it out - Nice truck
I helped out with the restoration
Great father's day present!!
AZ M37 for sale - eBay
Dave O
1951 M38
19XX M416
1944 Ford GPW
http://www.surfacezero.com/g503/showpho ... ppuser=452
1951 M38
19XX M416
1944 Ford GPW
I live in Tucson and called the phone number on the ebay listing never heard back . My brother and I want to see it. Is there another local number or do you not want locals to call? I am not trying to sound like a jerk we are serious about buying the right truck. Send me a PM if possible
thanks
thanks
viewing truck
PM sent w/Phone number
Dave O
1951 M38
19XX M416
1944 Ford GPW
1951 M38
19XX M416
1944 Ford GPW
fan shroud
Lifer, I talked to pete today, he told me that he sold all the shrouds to sid beck in victoria tx. so call sid maybee he has one left.
The shroud is a royal PIA to deal with so I can see why depots pitched them. We've had ours off/on at least a half a dozen times - to the point where Zac and I flip a coin - loser installs the shroud. The skin should be back on my knuckles by August. You have to sneak your hand in to access the 4 fan bolts blind. Pull the bolts, fan, spacer, and pully. Of course the fan has to be snaked out because of the clearance. Then you pull the hoses and 6 rad bolts. Then you lift the rad/shroud together up about 1/3 the way where you then have to sneak the shroud out around the water pump shaft and off the upper rad gooseneck, all while holding onto the rad in mid air. A few simple changes to allow the shroud to lift clear would have been a great idea back in the '40's.
Phew, I feel better now. What was the question?
