![Image](https://57hemicuda.smugmug.com/Cars/PW/i-CfGCMCN/0/L/004-L.jpg)
383 Mopar powered M37
- PFC
Re: 383 Mopar powered M37
I have a 71 Power wagon with a 5.7 Hemi/ 727 / 205. I wanted this one to have no electronics at all, but the 5.7 is a good choice for these trucks.
"Narrowing the diff is pretty straight forward, the long side just needed 3.5 inches cut off."
I just wanted to point out for others following 57Hemicuda's excellent work that his front Dodge DRW Dana 60 is about 2.5" narrower than the DRW GM version. Taking off 3.5"a front GM Dana 60 version would make the H1 rims stick out 1.25" further per side.
What an excellent, professional build. I can only dream of being such a master fabricator some day. Outstanding.
Is the rear axle also a DRW?
thanks
thanks
- PFC
I am not really sure what the back rear came out of, I went to a local junk yard with a tape measure, and started measuring the pile of 8 lug rears. I know its not out of a dually because its a 60, not a 70. If I remember right it was 71" wbs to wbs.
- PFC
36" of snow here in Maryland, mounted my plow, and i have to say this is one snow plowing machine. Its like a big Swiss Army Knife.
![Image](https://57hemicuda.smugmug.com/photos/i-QHVD2c4/0/L/i-QHVD2c4-L.jpg)
Nice picture of the M37 working on snow removal.
- PFC
Awesome Ron . look at you go ......mine stayed in the garage57hemicuda wrote:36" of snow here in Maryland, mounted my plow, and i have to say this is one snow plowing machine. Its like a big Swiss Army Knife.
![Confused :?](./images/smilies/icon_confused.gif)
When you made the modifications to the Dana front axle, did you go with a positive caster angle? With the different tires and power steering, seems like you would want some positive angle, instead of the 2-1/4 degrees of negative angle that the original Chrysler front axle was designed with.
Good question, I to am curious as i am blatantly plagarizing parts of this build!
Don't know how I missed those snow shots-outstanding!
- PFC
I did not change the caster on the front diff at all. It cruises 70 mph with the 37" tires with no wandering at all. The tires haven't ever been balanced, and it still cruises nice.
