My old Diesel M37 over the years
These are from back in the early 80's.
DG
DG
- DennisArmyTruckDetroit-1.jpg (53.27 KiB) Viewed 2343 times
- DennisArmyTruckPanel-1.jpg (45.76 KiB) Viewed 2343 times
- DennisArmyTruckDriveway-1.jpg (42.1 KiB) Viewed 2343 times
Re: My old Diesel M37 over the years
Late 90's early new century.
A couple young advocates of G741's...
DG
DG
- DennisArmyTruckSteveGary-1.jpg (56.16 KiB) Viewed 2342 times
- DennisArmyTruckCreekInRain-1.jpg (54.92 KiB) Viewed 2342 times
Nice job on the little details. The dash is great.
Funny, but looking at the pictures, I saw the license plate on the back and immediately checked your location. Thought the was a Historic Vehicle plate from AZ.
What is the engine series, 53 or 71 DD??
Don
Don
A 3-53N series. 159 CI.
I bought it new back in '77.
DG
DG
- Site Admin
What gearbox did you run DG and what was the dashboard panel from? (I want one
MM
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Spicer 3053A from a 2.5 ton Multifuel. About 16% overdrive. The truck would make 68 mph at 2800 RPM, 5.83 gears and 42" Goat tires.
Dash panel from same, with one gauge hole added on the bottom with a relocated hi-beam indicator. It takes up about half of the original dash heater hole due to the increased width, and is a little taller as well. Nibbler tool surgery was easy.
Thanks!
Dennis
Thanks!
Dennis
- Site Admin
Thanks Dennis, It has always been one of my favourite trucks over the years......
I do actually want one of these dashboard panels (minus all the parts, sheetmetal only), Has anyone got one kicking about the place?
MM
MM
PM me, I can help you out.
DG
DG
- Site Admin
