When I got my truck it had been converted to 12 V theoretically saving me the hassle of doing it myself. However, not having correct looking and lit by the red lamp gauges was driving me nuts. So I came up with a solution. It will help anyone going to 12 from 24 as it saves having to change gauges and senders and adding lighting circuits.
Special thanks to autodoc51 for supplying the original 24v guages and senders!
Just feed wire 27 from the ign switch to a 12vdc to 24vdc 10 amp converter. Output that to the spider harness.
Done.
24v 12v Easy conversion
