Like I said earlier, a whole host of different variables; cam choice, valve duration, vacuum, timing, etc... The primary function of the gearing/rpm table is give a builder options on gear selection. And its a two way street, a builder can either build the diffs to accommodate the engine, or vice-versa and pick a cam choice that best matches the gearing and tire size. The info in the tables however is not written as an absolute fact. Its more of a guideline than anything else.JimC wrote:Doesn't optimal rpm also depend upon manifold pressure?
In reality, and M37 isn't really any heavier than any other full size pickup, and its actually quite a bit lighter than the current crop of modern trucks, so really deep gears aren't needed for modern power to move the truck. But gearing is needed to overcome tire diameter, and the extra mass/resistance of larger tires, and to provide some feeling of control. Regular old 4.10's will spin a 37" tire without much issue, but it'll be a dog off the line, and shifting will be a necessity to keep it moving in the hills no matter what engine mods are done.
Just for amusement, with my 4.56's and 1100:16's I can just about hit 50mph in 2nd gear if I wind the 428 out to about 6000rpm. It sounds awesome, and sure puts punk kids in their place when I wanna' play "stop light to stop light"...
