What is this ?
churtle
What is this ?
Post by churtle »
All,
What is this ( transfer case, clutch, tranny, damn if i know) and i see gears in it, and what size is the plug and where can i get one at ? and what type of oil weight ....see picx.
I finished the last two shocks and finished the brake springs, remounted the brake drums and tomorrow will adjust the brakes and drum clearance and put the tires back on.....
cuz
Re: What is this ?
Post by cuz »
Have you a photo taken far enough away to see the entire assembly?
Rick C
Re: What is this ?
Post by Rick C »
My guess is the flywheel housing drain plug opening. Tough to tell with the pic. I do see what looks like a ring gear there....and maybe the oil drain plug to the left....
SOTVEN
Re: What is this ?
Post by SOTVEN »
Rick C wrote:My guess is the flywheel housing drain plug opening. Tough to tell with the pic. I do see what looks like a ring gear there....and maybe the oil drain plug to the left....
WOW, YOU HAVE A SHARP EYE RICK. I BET THAT THIS IS EXACTLY IT. HENCE HE COULD NOT TAKE A PICTURE FROM FAR ENOUGH. CHURTLE, THAT IS THE FLYWHEEL COVER AT THE BOTOM OF THE VEHICLE. THE GEAR YOU SEE IS WHERE THE STARTER GEAR ENGAGES TO AND TURNS THE ENGINE. NO OIL GOES IN THIS HOUSING. RATHER, THE HOLE THERE IS A DRAIN HOLE FOR ANY OIL THAT MAY ESCAPE THE ENGINE THROUGH THE REAR MAIN, OR ANY TRANNY LUBE THAT MAY ESCAPE TOWARDS THE CLUTCH. THE HOLE GETS PLUGGED WITH A SIMILAR PLUG TO THE ONE THAT THE OIL PAN HAS, AND YOU ONLY PLUG IT DURING DEEP WATER FORDING. THE REST OF THE TIME IT SHOULD BE UNPLUGGED. :)
Sal
Re: What is this ?
Post by Sal »
WOW...A lot of things use to look like that to me on a Sunday morning years ago , After a night of drinking lol...
Sal :mrgreen:
1954 M37 WO/W
1969 M101A1
SOTVEN
Re: What is this ?
Post by SOTVEN »
Sal wrote:WOW...A lot of things use to look like that to me on a Sunday morning years ago , After a night of drinking lol...
Sal :mrgreen:
HAHAHAHAHAHA!!! SOMEHOW, I KNOW EXACTLY WHAT YOU MEAN :D
Rick C
Re: What is this ?
Post by Rick C »
I rolled in at 2am .....barely functioning when I read that post!!!
Rick
churtle
Re: What is this ?
Post by churtle »
Gang,
thanks, for all the help, but at two am...im sleeping...LOL
