1952 M-37 missing plug
I'm new to this and not very mechanical so be patient. Under the truck there's a plug missing and I thought it was on the clutch housing. The mechanic that worked on it thinks it is the flywheel cover plug. It is 1 inch diameter opening and appears to have gears inside it. I can't find a replacement plug at auto parts stores. Any ideas? Thanks.
Hi Linda,
That hole is supposed to be open, unless you are fording a river. There is a plug for it, but under normal operating conditions it is left out. Both you and your mechanic are right, the clutch and the flywheel share the same space in there. The gear you saw was the teeth of the flywheel.
Hope this helps,
Tim
Hope this helps,
Tim
- PFC
Thanks for help with M-37
Thanks for all the help with missing plug. It's a 1952 M-37 truck last used by a rural fire dept in Oregon. Has the 6 cylinder engine with 24 volt electrical . Has no winch but appears to have the ability for one to be installed. New tires, canvas top and seats. Got it from the fellow who restored it in hopes of using it as a work truck on a ranch we are moving to. But now realize I need a newer truck that has power steering, brakes, etc. I love it, but wears me out trying to use it on steep, wooded terrain. And I can't afford to keep it just for fun. I have it listed for sale or trade on this site. Any ideas would be appreciated.
