Clutch pedal linkage
- HingsingM37
I need to know the center distance between the clevis holes on each end for the clutch pedal linkage and the OAL. I am making a new one and my old piece is bent and looks to have been "modified" by somebody trying to get more pedal height by welding in a bolt. Thanks
Re: Clutch pedal linkage
If yours is a stock set up, I can send you a good take-off. These pile up around here as we don't use that piece with a Cummins repower.HingsingM37 wrote:I need to know the center distance between the clevis holes on each end for the clutch pedal linkage and the OAL. I am making a new one and my old piece is bent and looks to have been "modified" by somebody trying to get more pedal height by welding in a bolt. Thanks
- HingsingM37
Is your mailing address the same as the Fed-Ex address?HingsingM37 wrote:That would work Charles. Thanks.
- HingsingM37
The rod is on its way via Priority Mail.HingsingM37 wrote:Charles,
Yes, that is my day job address and will work fine. Thanks again.
- HingsingM37
Merry Christmas & thanks again for the package you sent to me a while back. CharlesHingsingM37 wrote:Thank you sir. Let me know what I owe you for postage
- HingsingM37
