318 12v 24v
- SGT
318 12v 24v
Ok now that I put a 318 in my truck can I keep it 24v or do I need to swap to 12v if so what all needs to be changed.
May God grant me with the serenity to accept the things I cannot shoot, The ability to shoot the things I can and a place to hide the bodies
You can keep it 24V if you make some changes to the engine. First you would need to figure out how to hook up the mill 24V generator or altinator. Secondly you would need to either run the starter on 24V which will spin it really fast and shorten the life of it, or get a 24V starter or have the one on the motor rebuilt into a 24v one. Then you will need to change your coil to a 24V one or get a dropping resister to make it 12V at the coil. I'm going off of foggy memory here, but didn't the military use the 318 in another vehicle like some armor or something that had a military distributor (ignitor) so if they did you could try finding one of those and change your ignition over to a military setup with waterproof wires etc. Not sure if that is possible or not, but just a thought. I'm sure someone will post more information.
- SGT
The M880 318 (and the rest of the truck) ran off of 12V, some of the series did have an added 24V system to run military radios and RATT rigs, if you can find the 24V system alternator bracket it would make installing the generator easier, IMHO I would think it would be easier to do a complete 12V conversion, basicly change all the bulbs, guages and senders to 12V ones!
Ken
SFC USA (ret)
51 M37
52 M38
SFC USA (ret)
51 M37
52 M38
Just use a 12 SI alternator that has regulation built in
and chuck the regulator.
See Mad Electrical: here's a good URL
http://www.madelectrical.com/electrical-tech.shtml
J.B.
J.B.
