I posted this on PowerWagonAdvertiser, thought I'd try here too. My ETW1 wont run while I'm climbing. I've heard there's a Rochester that works much better, which model?
What's a good off road carb for the 230?
This is just my own experience, but I have had no problem what so ever with fuel delivery with my truck. I have ascended and descended my truck on grades where if you hit the brakes you will slide the rest of the way. I say put your money into a pro rebuild and call it good.
Keith
1989-94 USN Active Duty Seabees
1953 M37 W/W
1946 cj2a project
1953 M37 W/W
1946 cj2a project
Re: What's a good off road carb for the 230?
The original period.
On road, if you want better MPG we can say a Holley 1 barrell will do better, but when the road goes bumpy or climbing, the Carter is the king.
Juan Castro
Buenos Aires
Argentina
Buenos Aires
Argentina
It may not be a carb problem, was you gas tank full? A large angle with a not too full tank will starve the engine. And Lifer one step after the FI is what some Rock Crawlers are doing, PropaneLifer wrote:You seem to have a fuel starvation problem going on. Most carbs (including your ETW1) are capable of handling almost any incline if properly adjusted and with sufficient fuel pressure. If you plan to go vertical, though, direct fuel injection would be the way to go.
![Smile :)](./images/smilies/icon_smile.gif)
230 Offroad
I have a fuel pressure gauge on the dash that takes its reading right before the carb--it holds steady when the engine is sputterin/bucking as if the fuel level in the carb is low--like I'm running out of gas.
I know this ETW1 needs a rebuild, I was just curious if there was a better carb out there for wheelin, since that's what this I use this rig for.
Thanks all
Thanks all
