early transmission main shaft shim question
Attempting the assembly of my early synchro box and measuring and fitting the main shaft assembly. The spec in the manual is .040-.100 clearance between 3rd gear and stop ring. In order to make the middle of that range I need a shim that is .110 at the rear of the main shaft in front of the bearing. This seems excessive to me. Does this jibe with others experience or did I miss something?
Re: early transmission main shaft shim question
I'll need to check my notes, but here's what I remember:
We had more than 1/4" clearance with the orig. synchro assembly.
We replaced the synchro assembly with the new ones from VPW.
I believe I ended up with one .015 shim.
It seems that the synchros have a large effect on the shimming. I'm sure some of this is wear, but our orig. synchros were different in material and design than the new ones. I will say that the loosey goosey synchros we removed worked better than the new ones and we shot for the low end of the range when we shimmed the box.
I have the same conclusion as you, Andy. New synchro inner and outer stop rings and I didn't even need a shim. I'm at .043" clearance. Will have to see if it shifts! Just putting the finishing touches on the shifter top and the modifications and waiting on 1 part to finish the PTO. Should be done this weekend with entire drive package if I assemble a carburetor this week, also.
Then, to pull the old power unit and put this new one in.
